Yes, you can export data from Golioth a couple of ways.
You can set up destinations for your data using Golioth's data routing mechanism, Pipelines. You can set multiple data streaming destinations with custom filtering for each using this method.
Additionally, you have the option to manually export a CSV of device data and logs via the Golioth console.
